No sound by taking a picture!!
5 replies · 2,575 views · Started 06 August 2005
I know how to make silence pictures.
First you need the program ProfiExplorer. Go to Menu/Show/Hidden files and also ROM drivers. Than Z: will be visible. Open Z:/System/apps/Camera. Now you see, the last file "take_picture.wav. If you delete that file, you will make silence pitures. :icon1: DON'T DELETE IT FOR GOOD, REPLACE IT TO A PLACE WHERE YOU CAN FIND IT BACK!! REPLACE IT OUT OF THAT MAP TO YOUR PC OR SOMETHING. :icon1:
And you have tried this on your phone and successfully deleted a file from the Read-Only Memory (ROM)?
Somehow I doubt it.
You can see the files on the Z-drive, but you can't delete anything from it.
yeh i got to the file but it wouldn't let me move or delete cause its read only any1 know a way around this i have powerfile and filemanager
There is no way "around it". There is no software in existence that can be used to delete files in ROM (the Z-drive on the phone).
I'm sorry, I don't try to delete that file. I had seen that file, and thought that this was possible. I'm sorry for the wrong information :frown:
Kirbylover86 wrote:I'm sorry, I don't try to delete that file. I had seen that file, and thought that this was possible. I'm sorry for the wrong information :frown:
But there is two more better methods.
1. Play any songs in music player and decrease the volume and then use the camera and there will be no sound.
2.Use head phones and then click the snap and there will be no sound.
Hope it works with you.
