if i were to put my rsmmc + adapter in my 6230i would this work and a normal mmc card??? thanks
rsmmc + adapter in a 6230i???
yes it will. but not DV-RSMMC.
A dual-voltage (DV) card should work just fine. That's why it is called dual-voltage; it works both on devices requiring ~1.8V (such as the 6630 or 6680) or on devices requiring ~3.3V (such as the 7610 and others, including those that use full-size MMC cards, when you use the adapter). In other words, there is no reason why a DV RS-MMC wouldn't work in a 6230i.
