Nokia 3230 Gripes
4 replies · 2,415 views · Started 08 August 2005
The Nokia 3230 Good or Bad? :icon4:
Good! 😊
1Megapixel Camera
Bluetooth & Nokia PC Suite
Copy & Paste Function
Personal Ringtones & Pictures
Screen Size
Memory Card
Bad 😡
Annoying beep before calls or messages
Keeps crashing (getting almost daily) on Texts/Slows down --->
So Slow - Can you increase the basic phone RAM Allocation?
Can't send True Tone Ring Tones
Can't insert Names/Numbers into Text Messages
Poor Quality Speaker For Music/Loudspeaker
Can't remove Covers/Dust on Screen
Battery Life Short
Does anyone know of solutions to some of these (esp the software issues)?
all you can do about the above issues is contact nokia and voice your disapproval, apparently i am the only user to have experienced these problems!!
i got used to that...
chris_edridge wrote:Keeps crashing (getting almost daily) on Texts/Slows down --->
Dont have any of these problems...
chris_edridge wrote:Can't send True Tone Ring Tones
ofcourse u can...
chris_edridge wrote:Can't insert Names/Numbers into Text Messages
not sure about that...
chris_edridge wrote:Poor Quality Speaker For Music/Loudspeaker
it could be worst 😊
chris_edridge wrote:Can't remove Covers/Dust on Screen
u can remove it...im using my nokia for almost a month and i dont have dust problems 😊
chris_edridge wrote:Battery Life Short
its not so short...even though the screen size is very big...
MatejW wrote:i got used to that...
ofcourse u can...
it could be worst 😊
I have to say I'm pretty happy with it. Especially after the Motorola POS I had before. The 3230 does everything I could want...just need to figure out how to use an eBook reader.
"Keeps crashing (getting almost daily) on Texts/Slows down"
for this, there's a trick you can use, which i picked up when i owned the 6600 (that actually crashed more often than 3230). if you reboot the phone everyday, you won't get anymore crashes. a good time to do it is right before charging at night; just turn off, then turn on the phone, and then plug in the charger and go to sleep.
"Can't send True Tone Ring Tones"
try renaming the files to .doc or something. then send it using File Manager... that's always worked for me.
"Poor Quality Speaker For Music/Loudspeaker"
nokia has always been pretty weak in this area... the 3230 speaker isn't better or worse compared to 7610/6670. i haven't used 6630/6680, so i can't compare to those...
"Battery Life Short"
don't know what you've been using on your 3230, but i've timed myself, and i found i get 3.5 hours of talk time + 30 minutes other activities on a single charge. on my old 6600, i'd be lucky if i get 2 hours of talk time (and the 6600 has a higher capacity battery too).
