Fax sending and receiving problem
2 replies · 2,966 views · Started 09 November 2002
Hi there,
I have a problem with sending and receiving faxes. If I send a fax my communicater responces with: (while sending)
MSVServer
Reason=User
Code=44
After that he closes the server and message program. He also gives a remark "lack of resources" after the error.
After that I am not able to delete the fax from the outbox, I first have to open it and then delete it. Receiving gives the same error but after the error I can read the fax.
Does anybody knows how to end this problem? I have firmware load 4.13(6) and all programms are running from D: (MMC)
[email protected]
The lack of resources thing makes me assume that you don't have enough memory(ram) when running.
Try closing all apps with appman of switcher.
Or the old way press SHIFT-CTRL-CHR-K in the running apps like inter/office/calender/contacts/desk
It's just a suggestion. But it won't hurt to try 😊
