Does anyone else get "App. Closed eProfiles USER 11" ?
Mine wont work at all and says this to me everytime !
Ive mailled PSiloc and still waiting for an answer but just wondering if you folks had seen this b4 ?
no i did not have this yet...(V.3.12)
and i am was help to test out the eprofile...
so i had many different beta-versions on my phone,but never have this error.
have u e-profil pro?
witch version it is?
and your phone?
try to remove it,and the install it new,maybe this helps?
S�mi
Nah tried removing plus re-install twice already !
my phone is now on version 3.16 after nokia had it for 3 wks
and i am running Extended Profiles Regular
( They gave me free version for a few good ideas i gave them ) 😊
i dont now much about the regular,but it seems to be near the same then the pro.
send a mail to PsiLOC and explain your troubel,so they can work out.
S�mi
I have exactly the same problem, and have as well contacted Psiloc...no reply yet!
I get the same error message only when i try to read email messages from the SIM-card memory.
