Keep light On all time possible?
5 replies · 4,341 views · Started 10 August 2005
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 5.0; Symbian OS; UIQ; 316) Opera 6.31 [sv])
Hi! Are there any way to keep the light in On mode, right now it turns off after about 10 sec. There is an app for P910 that does the job TimePane which work great. I turn On/Off light with Power button. I dont wanna use it as a tourch and know there is Symbianwares Tourch. Can't find a way in Settings to change it.
janptr wrote:Wirelessly posted (Mozilla/4.0 (compatible; MSIE 5.0; Symbian OS; UIQ; 316) Opera 6.31 [sv])
Yes there are a number of programs, all based around the name Torch, Basically run it and it turns the screen white, hit the off hook button and go back to the main desktop of the phone or the menu button to run anything else. Some programs will effect the different versions and sometimes the backlight then goes off again, otherwise it will stay on with many other programs, viewing your pictures is very easy this way if your in no hurry to go through them all.
Duke.
Thanks for reply! I did in the end found a way in Settings to have the light On. Not a "One Button move" but it works with Symbianwares AutoExec pretty well, can configure a hotkey to do the job.
[Hi, would you be able to tell me how you managed to keep the lights on, its so annoying when you are using a car kit at night time, not to be able to see the buttons.
Sorry but the app that you need is FExplorer and not AutoExec. Maybe there is other solutions as well.
