c2Doom
3 replies · 2,564 views · Started 10 August 2005
Anyone got c2Doom working on a 6680 yet? On the loading screen, if I actually manage to get the bar to appear, it almost makes it all the way across the bottom of the screen and then does nothing.
I've even tried starting in safe mode, with theme set to default and used Appman to close all apps and non essential processes, and compressed the memory.
I get it to find the wad file and then goes to the "loading" screen and hangs. I think I'm using a bad wad file so if you can direct me to the doom1.wad (non commercial) file that should work with it, I might be able to get it to work..
Hey guyz.
I have the same problem. I have been looking around quiet alot but people dont give a proper guide. Rest of them are 6630 users who get so excieted that they can play the games on their phone.
Well here is my experience which may be helpful. I had the same problem with heretic. So basically the screen was staying at the loading page even when i tired it in flight mode or safe mode.
But once when I was trying, something interesting happened and it actually started to load properly and I could see a blue line underneath the guy walking showing the process of loading BUT unfortunately after the loading it just shows a blank screen. You can try it if you set your phone to SILENT MODE. If you do it you can see the game loads but again it shows a blak screen afterwards.
Well as I am aware the wads are working on 6630 and we know that there is no difference btwn 6680 and 6630 but just the extra camera AND THE 256 k SCREEN.
I am assuming that the 256k screen cause the problem as some ngage games have color problem on 6680 while they are running well on 6630. (basically they are made for lower quality screens).
Hopefully they will make new engines which support 256k too!
Again this is a presonal opinion so dont rely on it and try to search more and if you could find anything hola back! 😃
Just reset your phone before playing, and it'll work fine! trust me, im half way thru episode 2 of doom!
