Problems with powerlock
4 replies · 1,768 views · Started 12 August 2005
When i install this program on the phone, it acts strange, for example the screeen saver sometimes is the one of the phone an other times the one of the powerlock, besides sometimes freezes so i have to unplug the battery and restart the phone, any suggestions? thanks. 😊 😊 😊 :ciao: :love:
i just looked at the application's home page and there is no mention of a user guide or something similar - have you tried the help feature of the application itself?
i will load this up this evening and let you know if i can duplicate your problem, then see about a solution. 😊
Hi is me again from the messenger and nop i did nothing just unistall it and thats it, can you tell me if this programs works with this phone? thanks hope to see you again in messenger 😊
latinoguy wrote:Hi is me again from the messenger and nop i did nothing just unistall it and thats it, can you tell me if this programs works with this phone? thanks hope to see you again in messenger 😊
online now if you are 😊
and yes, they have it listed on the compatability list but i have not installed it as of yet.
ok - installed and tried it out. same issues you are having - it locks up the phone completely 😞 unless you absolutely need something like this, i would recommend not installing it at all.
