As the title says, is v5.22 for 9500 available for upgrade in the UK yet?
Cheers
xoio
Is fw 5.22 for 9500 available in the UK yet??
xoio wrote:As the title says, is v5.22 for 9500 available for upgrade in the UK yet?
Cheers
xoio
Yes,
Got my 9500 upgraded to V5.22 today in Portsmouth,
Carl,
CJackel492 wrote:Yes,Got my 9500 upgraded to V5.22 today in Portsmouth,
Carl,
Good news!
One thing though.... is upgrading the FW destructive... ie you loose ALL your installed apps, contacts, appoinments etc, basically everything? & should therefore be prepared to do a full re-install afterwards? or can the FW upgrade be 'nice' & not wipe everything out?
Secondly, have you noticed much change in how your 9500 performs & how it functions now?
Cheers
xoio wrote:Good news!
One thing though.... is upgrading the FW destructive... ie you loose ALL your installed apps, contacts, appoinments etc, basically everything? & should therefore be prepared to do a full re-install afterwards? or can the FW upgrade be 'nice' & not wipe everything out?Secondly, have you noticed much change in how your 9500 performs & how it functions now?
Cheers
1st, yes, you will need to make a backup first, either use PC suite or the built in backup (Easier to use the built in one, you can then start the restore once you get the phone back),
2nd, Calendar seams quicker, And I can now have blank operator logo's, 😉 😎
Will need to give it time to see if it's that much better,
Carl,
when i upgrade to FW, will the back-up software restore all my data including my SMS messages?
