Problem.. can't install most applications
5 replies · 3,049 views · Started 13 August 2005
I just had 6680 vodafone. I can not install most of the applications. even I couldn't install Adobe reader. I receive "operation failed" message on PC suite screen. I can install some programs like quick office or card deck, but almost 80% of the applications can not install.
Is it the phone or settings. I already enabled software installation.
mrkin wrote:I just had 6680 vodafone. I can not install most of the applications. even I couldn't install Adobe reader. I receive "operation failed" message on PC suite screen. I can install some programs like quick office or card deck, but almost 80% of the applications can not install.
eeeh...I assume you are trying to install Series 60 applications to your phone ?
did you turn Online Cerftif Check off??
manta wrote:eeeh...I assume you are trying to install Series 60 applications to your phone ?
yes sis files.
I tried to send the sis file to phone via bluetooth and install the app. in the phone.
It works this way.
