Problem with PC Suite - I can't backup my contacts
1 replies · 1,934 views · Started 13 August 2005
I'm trying to backup my phone using the latest PC Suite (available on Nokia's website), but for as many tries that I do, I'm not able to backup my contacts.
I'm getting this error:
Failed to copy the following data:
- Contacts
C:\System\Data\Contacts.cdb
I already tried the "reset phone" trick, but that only worked once. I reset the phone 3 times in a row and the error keeps on happening.
Best regards,
Norberto
i used to have same problem, at least until i bought new memory card. if you don't want to buy new mmc try this: eject mmc, restart your phone and then try to backup. you shoud be able to bakup then!
