I am really amazed none of you guys mentioned a topic about photographer and other camera software not workin on this mobile. what the hell is going on? why isnt these software not working. is the versions for this mobile not out yet?
Photographer & camera software
Well i can only guess no one uses it. The 3230 does have image editing software included as standard for cropping, rotating, colour, brightness, so is there a need for other software?
As long as the application is Symbian 7 compatable and O/S 6 revision 2 (i think thats what its called, correct me anyone) then it should work. The 3230 after all is only a slightly upgraded 7610.
Duke.
:icon14:
i finally found photographer 2.5 which is a good sign. but the problem i cannot find the crack anywhere.
Can someone help pls.?
gilbertgk, it seems that you somehow missed this when you signed up for the forums here: http://www.allaboutsymbian.com/forum/faq.php?faq=faq_rules#faq_rules
Sorry!!!!
dukesatan wrote:Well i can only guess no one uses it. The 3230 does have image editing software included as standard for cropping, rotating, colour, brightness, so is there a need for other software?
Where can I find this software on the phone?
Thanks,
Ian
I don't have a 3230 to verify it works this way on it, too, but open an image from Gallery, hit "Options", choose "Edit".
actually, it doesn't seem like you can edit the photo by choosing Options while in gallery (just tried, and that doesn't show up in the Options window).
ianmcmillan: the software came on the rs-mmc card. unless you moved it, it should just be in the menu somewhere. if you somehow deleted the file, i believe you can get it from the nokia.com site --> 3230 --> software & support --> Imaging (i think).
