question
1 replies · 934 views · Started 10 November 2002
hi,
if you had a demo (select) and the demo period is over. can you download the program again and play it whit your 7650?
thanks
I think most programs save the date of when they were 1st installed. So no, you can't. Seeing as they're really cheap, it's probably best to just buy them if you intend to keep using them. 😊
