Error In Makmake file when Importing (mmp) project
4 replies · 3,341 views · Started 15 August 2005
Hi, I'm Using Codeworrier for symbian series 60 2nd edition SDK, I downloaded the trail version of code worrier (personal edition), when I tried to open(Import) any (mmp) project through (CW) It gives me the following error message 😞failed to run MakMake), then another error message (system error: the system cannot find the file specified) after closing the message dialog it gives another message said (The Makmake tool failed to run .. project creation aborted).
I'm Working In C++ application.
MUB2000 wrote:Hi, I'm Using Codeworrier for symbian series 60 2nd edition SDK, I downloaded the trail version of code worrier (personal edition), when I tried to open(Import) any (mmp) project through (CW) It gives me the following error message 😞failed to run MakMake), then another error message (system error: the system cannot find the file specified) after closing the message dialog it gives another message said (The Makmake tool failed to run .. project creation aborted).
hi
i have faced the same problem..if u got any solution the do response..meok
hi
i think this may help u just try it out.
Downloading and installing Perl version 5.6 from the ActiveState site solved the problem. I retried importating an example from the ".mmp", and this time everything worked fine. so install perl version 5.6 ok
sonu1 wrote:hi
I install it but nothing happende , can I have more help from you.
hi
but how it can be possible..when i downloaded the activestateactivepearl 5.6 and again imported the example..it worked out...ok do one thng give me ur mail id so that i can send u the exe file of active pearl ok..may be it may help u..
