Is it possible to adjust the sensitivity or even disable the sensor that enables the keypad to light up?
I've found in a few situations that having the backlight on helps, but it's not dark enough for the sensor to activate it.
Ari
Ari
Ari9500 wrote:Hi,Is it possible to adjust the sensitivity or even disable the sensor that enables the keypad to light up?
Ari
cover ur light sensor with ur finger and it will light up! the licht sensor is located to the top right crner on a 6630 or on the top left corner on a 6680 phone!
