App won't work now but worked before
2 replies · 2,069 views · Started 17 August 2005
I've installed an app called FitnessAssistant and it was working fine but now after i installed some other programes it won't work.
It starts, flashes the opening screen as though it will start ok but then less than a second later it closes and i'm back in my menu.
I've not uninstalled anything to do with the program so i'm a bit stumped.
Also i tried to install Smart Movie and it installed but did the same as the other app(well it did it first then Fitness wouldn't work) so i uninstalled that.
If no one can help can i do a hard reset and if so how? I'm not worried about losing the apps i added just wondering if the phone would be ok.
Any help would be great.
neo866 wrote:If no one can help can i do a hard reset and if so how? I'm not worried about losing the apps i added just wondering if the phone would be ok.
Apart from uninstalling your prog, I can't think of anything. These are the reset options:
*#7780# - Soft Reset. (Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
*#7370# - Hard Reset. (Reformats the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten)
Wirelessly posted (Nokia 7610: Nokia7610/2.0 (4.0437.4) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Well. It happened with my smart movie too. It didn't work from the beginning. After various failed attempts to get it work by any way, i formatted the MMC and re-installed the application. It is working now.
