...Hello 😊
With message storer Im trying to make a backup of all the messages. I select all and choose "Save as text file".
Then I move the text file over to my pc to view it.
However all the messsages are all together but seperated by ---** symbols.
On Oxygen I used to be able to save the messages as a text file, but each message started on a new line
Is there anyway at all that I can get each message to start on a new line with Message Storer?
Thanks 😊
Wirelessly posted (Motorola v180: MOT-V180ENS/0B.D1.32R MIB/2.2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0 UP.Link/6.3.0.0.0)
The only thing that I can think of is just to use the ctrl + f command in your notepad to locate the ---** message break and replace it with a carriage return. It might be tedious, but it is a simple solution.
i am having loads of problem just trying to install the PC suite...as everytime i go to do it it keeps tellling me i have another version installed. I have cleaned the registry, folder, evrthing that had PC Suite or similar to it. I have also tried the registry cleaner from Nokia yet no avail. Does anyone kow if i can try anything different? Thanks
