As mac users will know - SmartMovie doesn't come on the MAC but there is an answer!!!
1. Get Forty-TwoDVD-VXPlus and install on your MAC. This is a trial version and will only do a limited file size. But perfect to trial. It is also COMPLETELY worth the modest registration fee.
2. Select your movie file/dvd file/VOB file and press OK!
3. Then select your output method as MOBILE, then Smartmovie.
4. Select GO, or OK and then START.
5. You will end up with an AVI file about 130mb for 2hr clip.
6. Install Smartmovie on your phone and copy the file to the memory card and you are off!
WARNING! - IT IS ILLEGAL TO COPY AND DISTRIBUTE COPYWRITTEN MATERIAL! IN SOME COUNTRIES IT IS LEGAL TO COPY MATERIAL YOU OWN OR HAVE BOUGHT FOR PERSONAL USE ONLY. PLEASE CHECK YOUR COUNTRIES LAW ON COPYWRITE AND INFRINGEMENT.
PLEASE DO NOT STEAL OTHERS WORK. YOU WOULD NOT LIKE TO GO TO WORK ALL DAY AND NOT GET PAID SO DONT DO IT TO OTHERS.
