hi guys, i have no idea why i can't open my theme folder which is originally put in the tools folder. once i click it, it did showed opening but then very fast back to the screen which is before i clicked(inside the tools folder). So is it something wrong or what ?please tell me if any expert know this...thanks
6630, theme problem
sam091 wrote:hi guys, i have no idea why i can't open my theme folder which is originally put in the tools folder. once i click it, it did showed opening but then very fast back to the screen which is before i clicked(inside the tools folder). So is it something wrong or what ?please tell me if any expert know this...thanks
Backup all ur stuff and then format the phone ,
Steps to format.
1. make sure the phone is off
2. pressed green botton + *+3
3. while pressing the bottons together, switch on the phone.
The usual two reasons for this sort of thing are
a)you're low on RAM and the app can't start up properly. Try closing ("Exit"😉 a few running programs and try again.
OR
b)the app is incompatible with the device. As Themes is a built-in, I'm guessing you want a) ... 8-))
A simple restart will sort out a) and also restart the OS. Does this fix the problem?
Steve Litchfield
