I regularly use the World clock with my 9500 and have found that there is a 1hr error between the UK and pakistan (where I often travel). Is there a way to de-bug this or do I need to wait for Nokia to get around to it?
Nokia World Clock Bug
Check your basic clock settings - do you have daylight savings time activated? I had the same problem with world clock on my old 6600, I found that if I deactivated daylight savings time then world clock would behave - I haven't tried world clock on my 9500 though
I travel to India and have seen the same problem. Puddytat purr is right though, I found that by fiddling arround with the daylight time settings in both zones, I eventually got it to work properly. I had to turn off the automatic time update function 1st.
