Urgent help needed!! Can't write a letter in 6630!!!!
9 replies · 2,577 views · Started 20 August 2005
I can't write letters in browser, mms, notepad or any other program. Can't open T9. I have tried # key, number mode-ABC mode changing key. No way. Has some been accidentally deleted? Pls help...
i had installed it once, wildskinz i mean, and then uninstalled it.- after the problem appeared, and it still is no good- but thnx a lot anyway.
But did you deactivate it before uninstalling it - else it leave bits in the phone that screws it up and gives these exact syptoms.
May be worth trying this..
Install wildskins
reboot
activate
reboot
deactive
reboot
check it is really deactivated
uninstall
reboot
That way you will be sure it is clear from the phone..
If it is not wildskinz I would be suprised, but check your phone for any other 'old' applications and try uninstalling those.
I even formatted my memory card, i have only lifeblog and lm pro installed, i still have the problem. Can it be a missimg file or such? Btw, 10x again bill..
Reformat your phone, or Reinstall WildSkinz, enable/activate it, reboot, disable/deactivate it, reboot, uninstall WildSkinz, reboot.
Reformatting the memory card is not enough, the fact you are getting an error on startup only confirms even more that it is the wildskinz bug.
The startup file is on the phone mem - it tells the phone what to run on startup.
Because wildskinz was not deactived before you removed it the startup file is still looking for it - that is the error you see everytime you start the phone...
I may of course be wrong, but you asked for advise, this is the advice, why not try it and see 😊
If that fails then we can look elsewhere.
Rgds
Will
i have done all you have told, and still nothing. i still get the system error, still cant write letters. :frown: :frown: :frown: :frown: :frown: :icon13:
