Need help unlocking MMC card
5 replies · 14,014 views · Started 20 August 2005
Hello, I have a Nokia 6230 with a locked MMC card (I got a replacement phone from Cingular, but my old MMC card no longer works in the new phone, both are 6230's)
I have read online that it is possible to get the MMC password using Seleq or FExplorer. However, my 6230 does not support these applications, and I don't know anyone with a Symbian phone.
Would anyone on this forum be kind enough to be willing to unlock my MMC card using their symbian phone?
If you are willing, I will mail you my MMC card (using regular mail) with an addressed return envelope. It won't cost you anything except a little time and I would be extremely grateful.
The instructions for getting getting the password are:
1: Use any efile manager like SELEQ 1.65
2: Open SELEQ 1.65 and go to Root C:
3: Options and FIND, write MMCSTORE press OK
4: Send this file by Bluetooth or Infraread to your PC
5: Rename the file MMCSTORE to MMCSTORE.TXT
6: Open the file and the password off the MMC are there
Again, I would be extremely grateful if someone was willing to do this favor for me, and really don't want to have to buy a new MMC card (or lose my data on the card).
Respond to this Thread or email me at [email][email protected][/email] if you are interested,
Thank you
Memory Card lock code
Try This
If you know the password, and want to remove it, go to Extras > Memory.
Goto Options > remove mmc password
N/A wrote:I replied to another one of your triplicate posts.
i had formated mmc card & phone now it shows password
Try to format ur MMC using Nokia 9210 or a digital camera. Otherwise, try to use 3rd app 'mmcpasswd' (google 4 it).
