hi, does any one know how i can install the webviewer for the 7650? i have downloaded it and it comes zipped up, when i unzip it, i get webviewer.jad and webviewer files all zipped up (again)
how did other people install it?
thanks
NK
thanks
NK
send it like you would a ring tome from your PC m8e
I.E. IRDA Kit or Bluetooth - It is then located under Appliactions in Tools menu as it is Java software
Just extract the zip file, then send the .jar and .jad files to your phone.
Install as you would with any other app.
If you have problems after that (browsing the web), change the default gateway of your access point to 0.0.0.0
This worked for me.
Cheers,
Tsu
A short point about jar and jad files....the 7650 does not need the jad files just the jar....it saves time and effort 😊
