How to customise a fax template
5 replies · 2,511 views · Started 10 November 2002
I want to create a personalised fax template with our company logo etc... How do you do it?
N 😃
You just need to eidt/add the the files in documents/Templates/fax if you open full template you will see all the keywords that you can use.
I will have a go tonight, but can you add logos and special text in places you like, etc... or is it limited
Nick
The templates are normal wordprocessor files so you can add test, layout and pictures. I added my company logo.
Though the special fields are abit limited.
Oh well.
