3650 Text Messaging error
2 replies · 2,126 views · Started 22 August 2005
My 3650 crashed a couple of months ago. It was displaying all sorts of errors. One of them was the text message sign would show up constantly even when I am not sending any message.
I did a backup using the suite and then did a master reboot, and copied all the data back from the PC. After copying all the files back, I still get the constant text message sending sign.
Please note that I can send and receive messages without any problem its the sign in the corner which is displayed all the time.
Has anyone experienced this problem before? Anyone knows how to solve this irritating thing?
thanks in advance.
N/A wrote:Any leftover (failed to send) messages in the Outbox?
yep, found some undelivered text messages. Deleted them and the icon has gone away.
thanks a lot for your advice. I was expecting it to be a little more complicated solution than that.
