http://www.dornhoff.net/index.php?/archives/169-Blackberry-Client-fuer-Nokia-93009500.html
Caveat, i have not tried it since my 9300 is having a face lift. Can someone download it and try and see if it works
THanks
Claude
THanks
Claude
Here's the page translated in English...
Trackbacks
TRACK-BAKE for specific URI of this entry
BlackBerry Connect Client for Nokia 9300/9500 available
For few days finally the BlackBerry Connect Client for the Nokia 9300/9500 is available. Minimum requirement is however firmware 5.22nd [ list of Nokia service partners for software Upgrades ] Download of the BB Connect Clients. [ via: dornhoff.net ]
Web log: mobile6.de
Taken up: August 25, 08:59
Then when u click on the link to download.. this is what comes up..
Minimum requirement is however firmware 5.22. [list of Nokia service partners for software Upgrades]
I tried it on my 9500 and it works, thanks for the tip, Claude !
I just installed the .sis file and then inserted my sim card with Blackberry activated.
In control panel/messages settings, a new menu appears named "Blackberry". There, I just had to turn on the Blackberry service and everything is configured automatically, the information was probabely on the SIM card...
Then I received a message with a link to connect to the Blackberry web interface, logged in and just had to notify a change of terminal. That's all !
NB. Yesterday I updated the firmware to 5.22 as required for this sofware.
Tiramisu
All,
Great Forum.
I downloaded and installed all of the necessary software. Acording to the Application tool on the 9300, the BB Connect has been installed correctly. However, when I go to the "Messaging" section to set up the BB Connect, "BlackBerry" is not showing up. I tried reinstalling the SIM card, turning off, on, and reinstalling several times.
Any thoughts?
Thanks in advance,
Jeremy
Jeremy,
I'm not a specialist, I was just lucky it worked the first time...
I can just tell you how I installed it.
First I went to the shop to upgrade to firmware 5.22, this is mandatory !
I have a french 9500...
I installed the .sis file from my computer, not from the Communicator.
Then I went to Control panel/Messaging/Blackberry and in the first tab, I did "activate" Blackberry. All the other settings have been automatically set up from the SIM card I suppose.
After that, I received a mail requesting activation of my account. I had to follow a link and reached my Blackberry account on the web interface. There, at the bottom of the page, I had to change the terminal where I receive the information. As I did this from my Communicator, it was recognised and IMEI and other codes were automatically filled in the fields. Save and exit and there I started receiving all my mails.
Hoping this will help you a little bit...
Tiramisu
Hi Jeremy,
Did you manage to get your nokia working with the blackberry connect software? i have the same problem, where i have installed the software, all the help files are there, but no blackberry menu option exists on the message menu - Control panel/Messaging/Blackberry.
Smiffy
smiffy wrote:Hi Jeremy,Did you manage to get your nokia working with the blackberry connect software? i have the same problem, where i have installed the software, all the help files are there, but no blackberry menu option exists on the message menu - Control panel/Messaging/Blackberry.
Smiffy
smiffy wrote:Also, i have tested my sim card with blackberry enabled in a blackberry phone, and it works fine. I just need it to work in a nokia 9300, as I want a better functioning phone.Thanks
I have justgiven my 9500 to update to 5.22. Once I get it back from where do I get the blackberry software.Does Nokia provide it or is it a seperate issue.
Nilesh
