Profimail automatic startup
1 replies · 2,123 views · Started 24 August 2005
Hi folks,
I've had the trial of Profimail 2.24 on my phone for a couple of days. I like everything about it so far. I have it check my mail every 40 mins during working hours, I don't need it when I'm home. I was wondering if there is anyway I can get it to start up automatically when I turn my phone on. I don't turn it off a lot but it's a bit annoying having to check it's still running. Any way of doing this?
Cheers,
Ben.
Well I've found a program by Psiloc called Autostart which claims to do what I want. You add to a list the applications you want to run at startup. This doesn't seem to work. The programs on the list only execute when I manually start Autostart. I was thinking perhaps the other 2 apps that I have, which autostart are causing this problem. They are FSCaller and Autolock.
Ideas anyone? I really want to buy and use Profimail but not until I get this sorted.
Cheers,
Ben.
