A925 battery problem
2 replies · 4,201 views · Started 24 August 2005
:frown: [FONT=Arial]undefined[/FONT] Hallo All,
I just got a Motorola A925 but seem to have a severe problem with it. If I am not using the phone for about 5-6 hours it switches automatically on, that is, is switches on the display. This happens especially if it is key locked. If I do not notice it the battery is de-charged in few hours. After that the clock has been reset. DOES ANYONE KNOW HOW TO FIX THIS PROBLEM??
Carl X
Hi i sometimes had the same problem. All i can tell you is that a Firmware update will probably do the trick. The A925 was and is bit Quirky!!!
