TMMessageAgent - An Unknown task found by Sman - Any ideas
0 replies · 1,824 views · Started 24 August 2005
Hi All,
Hope this is the right place to post this question - apologies in advance if its not.
I've had my p900 for ages and installed/uninstalled all sorts of software on it, not had any problems with it so far.
Recently though, when using Sman (to end some programs and free up some memory) I've seen a task called: TMMessageAgent
I don't remember seeing it on the list of running tasks before and when i try to end task, it restarts itself automatically so i cant get rid of it.
Is this a common system task that i shouldn't worry about? (Does everyone have this running?)
Or is it something nasty i should be worried about?
I've tried a google search - got one result from a Chinese website but thats it.
Many thanks for any help on this one.
Cheers, Alex
