A1000 Startup problem
4 replies · 3,439 views · Started 25 August 2005
Could anybody help me to startup my A1000. It doesn't bootup properly. It "hangs" where motorola sign an 3G is blinking. Someone said in the other thread that he would flash the phone. How do I do that? maybe any other solution?
what were you last doing wen your fone was working? did you try changing the system font through SMan?
anyways, as for the solution -> are you in the United Kingdom? If yes, and if on the 3 network, call the 3 helpdesk - just tell 'em your phone doesn't boot properly and dont tell them about any extra applications you installed - just show you are pretty unsure of what the problem is - and they'll get it flashed for you, absolutely free!
Though, you'll end up losing your media and content - most of it, if not all..
