wav and midi
4 replies · 1,523 views · Started 11 November 2002
Hello,
I only have infrared here... I tried to send a .wav to 7650 but it failed. Maybe because the file size is to large 😞
can someone guide or suggest for a program that is capable of converting the .wav to .mid and/or a program that will reduce the size of .wav file?
Thank you in advance.
this been asked bfore
pls try to use the search function and search for "Wav" or "Midi"
and u'll find the answer
:angel: :angel: :angel:
[quote="daniatt"]Hello,
Thank you in advance.[/quote]
you can simply download midis in the internet and send that to your phone via IR
yup! but I have a particular sound file here (in .wav format) that I wish to transfer into my 7650 but I only have infrared and it always failed to be transfer 😞 so I thought that converting this sound (.wav) to midi format before transferring will be the solution... this brought me in asking here for a suggestion what program to use to conver wav to midi.
Thanks for the input 😊
It's ok now guys..
I found IntelliScore 5.0 http://www.allformp3.com/mp3_other/mtm.htm that can convert MP3 and WAV files to MIDI
