Hi all,
my 3230 shows a strange icon on the screen. for your reference i have posted this icon as a gif. please suggest me a way to get rid of this
Hi all,
it means there is a message in your outbox sending or trying to send...
it will stay there if u had a failed message.. delete the messages in "outbox"
its in the manual 😉
i tried that but i cannot see any messages in my outbox
Try turning off the phone and seeing if that removes it, otherwise did you run the message conversion program to set your messages to the MMC card?
Its possible if you did that while a message had not been sent its now stuck in the phone memory when your messages are in the MMC. Simplest cure if this is the case is remove the power, take out MMC, turn on phone, wait for it to start up, check messages which should now be back to phone memory and clear out any problems, turn off replace MMC, power up and check all ok, run MMC converted program and your back to useing the MMC after another quick reset (just to refresh memory settings)
Otherwise i'm as puzzled as everyone else.
Duke.
