Is there any way to mute or reduce quickly the sound from an aplication in 9300?
mute sound
One thing you can do is change the profile to silent.
Rafe wrote:One thing you can do is change the profile to silent.
Thanks but your sugestion didnt work. I was talking about the "pda" sound not from the phone sound.
I will give an example:
I need the alert on to agilemessenger to be notified when arrives the 1st message. After that i dont need the sound so loud, so what i want is a short cut to reduce or mute the sound in the pda, since the application does no support it in a easy way.
