Operating logo
3 replies · 2,124 views · Started 11 November 2002
My 14-days trail has expired on SeleQ1.20i n I try to reinstall with older versions but no luck. The only way is to do a hard rest on my Nokia 7650, which I do not want to do just for this feature.
I would like to change my T-mobile operating Logo to the colour one below. Is their alternative way to do this?
Manually using another filing manager or is there a freeware/shareware that is dedicated to change operating logos on the Nokia 7650.
If this question has been answer already (because a done a search) please post tips or suggestions
P.s
I thought Active Desk was capable of do this. Function.
maybe try to use the other file manager such as efile manager or handy file but with this u must do it manually not just like seleq with single click.
for how to do it manually pls search the forum for the "Operator logo"
you'll find a detailed bout ur network number and how to change it
:angel: :angel: :angel:
[quote="Anonymous"]My 14-days trail has expired on SeleQ1.20i n I try to reinstall with older versions but no luck. The only way is to do a hard rest on my Nokia 7650, which I do not want to do just for this feature.
P.s
I thought Active Desk was capable of do this. Function.[/quote]
hmmm, i'm guessing u loved seleQ, if i guessed it right, it's about that time to bring out the credit card and buy the app!!! u make yourself happy as you will make the creators happy!!!
final word: it's worth buying it brah!
