Formatting Phone???
7 replies · 2,308 views · Started 26 August 2005
Hi guys,
I think I have screwed my phone up by not uninstalling applications properly...
I want to format my nokia 6680 however I would like to know what happens when you do.
Will all the pre-installed applications go as well? For example realplayer?
Cheers
If I do the Hard Format, will all of the Orange/Nokia Pre-installed software be on the phone after the format?
I assume that the user installed apps will be erased. However there are other progs that I don't want to lose... ie realplayer
Cheers
kiniki2005 wrote:If I do the Hard Format, will all of the Orange/Nokia Pre-installed software be on the phone after the format?
Cheers
Didn't I tell you already these apps will stay? EVERY pre-installed app will be there again.
Hi ??? I am raj frm UK i am having a problem with my mobile it have got a virus if someone can help me email me on [email][email protected][/email] Thanks >>> :redface:
