PC connect using blue tooth
3 replies · 2,120 views · Started 27 August 2005
Hi ,
I got a bluetooth dongle , how can i use pc connect with this , i dont find any BT option in it , after installing the bluetooth software i find many com ports with cable as connection in mrouter
please help
You need to update mRouter yto the latest version (3.1)
Once you've done this, you'll be able to use bluetooth with pcConnect without any problems. HOWEVER, the new mRouter does make it almost impossible to use the USB (data) cable, so it's a case of one or the other I'm afraid. (the good news is that BT isn't noticably slower than USB)
stuclark wrote:You need to update mRouter yto the latest version (3.1)
ohh the new mrouter is not detecting my bluetooth software , i added manually the ports in it , still its not able to connect , now iam not able to connect either using dongle or usb cable please help
:frown:
To connect to mRouter over bluetooth, u firstly need to setup a bluetooth serial port connection.
To do this go to My computer > Bluetooth places > Bluetooth Setup wizard ( on the task menu @ the left)
Follow the instructions in the wizard and you shud be good to go.
This works with both mRouter 2.2 and 3.1
