Hey all, sorry for asking a nooby question but ive looked thru manual, thru the sony website and this sites search engine and im banging my head here.
For some reason my keylock no longer is available. I pull the dial towards me and instead of keylock being first option, its now silent. I cant find keylock anywhere in options, except automatic, which doesnt seem to come on.
I havent updated any firmware, or anything. I just cant find how to turn my keylock on anymore??
Any helpful suggestions most welcome.
i don't think you can "keylock" manually. it will automatically lock it for you after several seconds. Have you check your "LOCKS" under control panel? there is a tickbox for automatic keylock.
Yeh for some reason it didnt work when i first put the sim card in, then after trying old one, it worked - the manual keylock came back on.
I noticed it comes off when i put in the charger, and i cant access the manual keylock anymore. When i remove the charger it comes back. Strange, though is working now.
Cheers for the response anyway 😊
