my headset is not working properly
7 replies · 2,836 views · Started 30 August 2005
hi ,
my headset not working properly , can i use any other company headset for sendo , i don have any service center in my country .Please help
venkat_t3 wrote:hi ,
Venkat,
Search on this forum for 2.5. You may find that information useful.
MangalPandey wrote:Venkat,
Thanx mangal pandey , is tht means , i can use any 2.5 mm headset??
I bought a 3.5 to 2.5 mm jack converter, but somehow the volume in the headset I also bought is very low and mono. I tried fiddling around with the connection but nothing worked. Maybe it has something to do with the extra mic connection for the original Sendo headset. Eitherway I'm scr*wed, cause the original one also doesn't work anymore. (Before using the new one)
I guess a jack converter should work, but it didn't do the trick for me... :frown:
trimakassi wrote:I bought a 3.5 to 2.5 mm jack converter, but somehow the volume in the headset I also bought is very low and mono. I tried fiddling around with the connection but nothing worked. Maybe it has something to do with the extra mic connection for the original Sendo headset. Eitherway I'm scr*wed, cause the original one also doesn't work anymore. (Before using the new one)
The MPxAA works perfectly for me (http://pc-mobile.net/mpxaa.htm). It's got a volume control, built-in mic, can be used with any kind of headphone you want and it's stereo. It comes with an earbud if you just want to use it as a heaset.
i think u r also from india.. i want to buy sendo x .. where shall i buy it from.. tell me some trusted seller. is it wise to but sendo x or not??
amit_nikam wrote:i think u r also from india.. i want to buy sendo x .. where shall i buy it from.. tell me some trusted seller. is it wise to but sendo x or not??
Sendo x is a great phone , i like it , but its wise not to buy sendo x now , because the company is no more , my sugesstion is try out some other phone
Well, if you don't mind not having warranty or support, I'd go for a (rather cheap new) X. If you do care about that, then maybe one of the new N-series is an option?
