Panasonic X700 WAP problem
2 replies · 2,540 views · Started 31 August 2005
HI EVERYONE,
i have a panasonic x700 and i love it, BUT
i have downloaded and manually set up a variety of WAP settings. it seems to connect OK but i cannot get any wap pages.....
The browser stays blank and shows 0kb downloaded. after a while it times out and a dialouge box comes up and says "no response from gateway"
any ideas?
cheers
A worried man :dontknow:
Get (from your operator) settings for a Nokia 6600 (Series 60 2.0). Those will work with the X700. Or try Nokia's settings pages: http://www.nokia.com/nokia/0,,71993,00.html
Make also sure your plan/subscription allows for WAP access (if for some reason your operator requires it to be enabled separately).
