Celltrack on 6680
4 replies · 2,276 views · Started 01 September 2005
Just put the version for os 6 on
Just looking at the options on celltrack now and it says that my s. os is 8.0 though
Does this mean Id be better off taking this version off and putting the version for os 7 and higher on?
Cheers
Nish
It says your os is v8. It is so whats wrong with it?
My version shows me I have OS v6 but I have v8.
Ah get you now 😊
Just to reduce any errors that may occur in the future Im going the put the version for os version 7 and above.
Thanks 😊
