Years ago, Rafe and friends started on a supplementary guide to making the most of the 9210 which I found so much more absorbing than the standard manual. Is there a similar resource for the 9300?
I am especially keen to know how best to make use of pdfs (refreshin/drawing is lethargic), videos (how to convert from mov files to the format used by the 9300) and web pages (can I set up a home page that acts as a map of all the stuff on my main computer) on the 9300?
Tahir wrote:videos (how to convert from mov files to the format used by the 9300)
If you get Quicktime Pro V7.0 it can output MOV's to mp4's which can be played on the 9300/9500,
I think V6.5 could also output to mp4,
You need the pro version (Paided version) so you can save and export,
WMV's are harder to convert,
Carl,
Tahir wrote:Years ago, Rafe and friends started on a supplementary guide to making the most of the 9210 which I found so much more absorbing than the standard manual. Is there a similar resource for the 9300?I am especially keen to know how best to make use of pdfs (refreshin/drawing is lethargic), videos (how to convert from mov files to the format used by the 9300) and web pages (can I set up a home page that acts as a map of all the stuff on my main computer) on the 9300?
Can I plug my own 9500 tips page here? There are sections about videos in particular. http://3lib.ukonline.co.uk/
Not quite sure what you mean about the web page. Can you explain in more detail?
Steve Litchfield
