2 flash lights for nokia 6680?
1 replies · 2,600 views · Started 06 September 2005
Does the nokia 6680 have 2 flash lights for the camera???? On the front off the phone there is a clear little circle on the the top left hand corner, Is that a light?? if so how do i put it on? can anyone help??
My phone is on the Orange network.
Thank you in advance.
sayeed wrote:Does the nokia 6680 have 2 flash lights for the camera???? On the front off the phone there is a clear little circle on the the top left hand corner, Is that a light?? if so how do i put it on? can anyone help??
It's not a light it's a light sensor. It dims the keypad and the screen to suit the lighting it senses. If you read the instructions they will tell you this.
