hellow, i�m from spain my inglish is very bad but i will try them.
My sendo x have many problems, i can�t call many times, it seems that it loses cover.
I have not proven to update and follows equal, I have either obtained update in Spanish who works for my movil, where I can download it?.
Can be changed to the language from some sendo�s menu?
No problem...
If I understood you correctly... you are looking for a spanish update frimware for your sendox? 😉
You can download it here : http://www.sendosmartphones.com/index.php?/component/option,com_docman/task,cat_view/gid,27/limit,5/limitstart,0/
Updateing to the newest firmware, choose spanish as language...
have fun! :itsme:
but in the page that your you say to non encounter a Spanish distribution to me.
In where the language of the sendo changes ?,
There is some menu for it ?,
me you could explain step by step ?
Thanks.
peconrrixico22 wrote:Thanksbut in the page that your you say to non encounter a Spanish distribution to me.
Thanks.
Hola 😊
I�m spanish so you can PM me if you want :P
(Te puedo echar una mano si quieres, env�ame un mensaje privado. Yo tb tuve problemillas con eso)
Cheers! (saludos 😊))
Hi morph !!
Nice to meet you ( a ver si podemos hablar por messenger tengo muchas preguntas que hacerte gracias).
