Mms
1 replies · 1,656 views · Started 07 September 2005
Hi. Can you send any file type in MMS or just the ones the phone knows about. I wanted to send a MS Word doc to a friends PDA phone, but I could not add it as an attachment.
Any Ideas ?
Also, is there a version of MS Word that will run on the 3230 ?
Cheers
MMS standards specify what the format is and what kind of files you can send. The key document in finding out what that is, is the so called "MMS Conformance" specification, which should be downloadable from somewhere on the OMA (Open Mobile Alliance) web site: http://www.openmobilealliance.org/
Use email, if you want to send attachments like Word docs.
See QuickOffice (QuickWord, etc.) for software to view or edit Microsoft Office format documents on your phone: http://www.quickoffice.com/
