hey pls help me, i dunno what is the problem....
but one time i was going in gallery and i was goin in the images... it said opening images with that waiting bar....it went on and on...so i restarted the phone.... and it wouldnt restart....the nokia logo came n it went white again...this kept happening....so i removed the memory card and restarted the phone, and it worked...so everytime i have to start the phone i have to remove the memory card...and sometime i try to do something like go in gallery it happenes again...but very occasionally.... if anyone has a solution....do let me know...i hope i dont have to send my phone....
thnx
ok u have to put the memory card into a pc, and run chkdisk on it, by going to my computer and right clicking on it then tools anc click check now under error checking. that should temp fix it, but the memory cards that come with the 6680 are very bad, try to get a different one asap
fijaz_ wrote:hey pls help me, i dunno what is the problem....but one time i was going in gallery and i was goin in the images... it said opening images with that waiting bar....it went on and on...so i restarted the phone.... and it wouldnt restart....the nokia logo came n it went white again...this kept happening....so i removed the memory card and restarted the phone, and it worked...so everytime i have to start the phone i have to remove the memory card...and sometime i try to do something like go in gallery it happenes again...but very occasionally.... if anyone has a solution....do let me know...i hope i dont have to send my phone....
thnx
hi fijaz
take your phone to where you purchased it and ask for a firmware upgrade and a new memory card as from my experience you will need this either now or in the near future
check this link for other faults due to firmware corrupting the memory card
http://www.allaboutsymbian.com/forum//forum/thread/39744/
