Problems with battery of sendo
8 replies · 2,607 views · Started 08 September 2005
Why the battery of my telephone that I finish buying hard so single hours ?, There is some solution ? , Whichever lasts the battery to you ?
After fully charging I can use mine for 2 to 3 days. Maybe you have some heavy applications running in the background like bluetooth or mp3player?
Which firmware version do you have on the phone?
When did you buy the phone - how old is it?
Can you see a red light when looking into the IRDA port on the left of the phone?
How long in hours, does your battery last?
It is the Portuguese version.
The telephone me I bought it days ago.
The light of the IRDA permanently is ignited.
The battery lasts 4 hours without doing nothing.
Any solution?
Which version number of the firmware are you using? (type *#0000# to find out)
Did you buy the handset new or second hand?
You are suffering from the IRDA bug - we need to know more about your handset to help you try to fix the problem. It would be helpful if you could enter your IMEI and SPN data from the phone on the special form at the Sendo Smartphones website. The link for that form is: http://www.sendosmartphones.com/index.php?option=com_philaform&Itemid=51&form_id=1
Ok, completely I am interested in your help.
What it si IRDA Bug??
The telephone is new.
My IMEI is: X1.198.8.2 Release IG 19-May-2005
�What it si SPN Number?
I feel it but I am of Spain and the English I dominate it rather little
You are suffering from the IRDA bug - we need to know more about your handset to help you try to fix the problem. It would be helpful if you could enter your IMEI and SPN data from the phone on the special form at the Sendo Smartphones website. The link for that form is: http://www.sendosmartphones.com/index.php?option=com_philaform&Itemid=51&form_id=1[/QUOTE]
I have a problem too with the battery, is not as bad as peconrrixico22 problem, but according to Sendo the battery should las at leas 170 hours, but instead it only last for little more than two days, that according to general knowlege are 48 hours.
I have recently install the new Firmware from SendoSmartphones.com and don't present the so called IRDA bug, becaus my IRDA doesn't even work (which actually I don't care, since I use the USB or Bluetooth)
the SPN I don't know which one, since I upgrade my phone it says it has a 00000000000 SPN (does that means that my phone is unlock???)
If someone knows how to improve the battery time... Please.
I do not understand much English.
But the problem of the IRDA has some trustworthy solution at this moment?
I also am going to update with firmware official to see that it happens, but repeat the problem of the IRDA has some trustworthy solution at this moment?
