Rogers ( Canada ) Email MMS GPRS settings
by machman
Hey all.
Finally got all the settings working for Rogers (Canada).
I can now access the internet and receive MMS.
Thanks to PXer, machman, and spud for all their help.
I'm posting all my settings here, so in future any other Rogers users won't have to struggle.
Mods. could we make this a sticky in tips and guides?
CTRL panel --> Connections --> Internet accounts
You'll have to use GPRS editor if you've already got an accout set up.
SERVER
Account name: Rogers WAP
check - username and password required
username: wapuser1
password: wap
(both are case sensitive)
address: goam.com
tap LOGIN: leave as automatic for IP and DNS
tap PROXY: check mark proxy server
Proxy server: 208.200.067.150
Proxy port: 8080
for MMS
create a new account called : Rogers MMS
Connection type: GPRS
tap on ADVANCED
address: media.com
check mark USER/PASS required
USER: media
PASS: mda01
(both are case sensative)
tap LOG IN: leave as automatic for IP and DNS
Proxy server: 172.025.000.107
Proxy port: 9201
tap on done (three times) till you return to the main menu for internet accounts
Now tap on MESSAGING ACOUNTS
tap on the right arrow till you reach MULTMEDIA MESSAGE
MM mesage gateway: http://mms.gprs.rogers.com
Internet account: (drop down menu) select Rogers MMS
check mark PROXY SERVER
PROXY ADDRESS: 172.025.000.107
PROXY PORT: 8080
tap on ADVANCED
Message valid for: (drop down window) MAXIMUM
Auto Download: ON
I'm not sure why the proxy ports are different, but this is the only way I could get it all to work
//Thanks goes to dpg79 for these settings!
Attachments: None
