FM Radio on the 6680?
9 replies · 12,862 views · Started 09 September 2005
Is there an FM radio on the 6680, if so where???
I can't seem to find it and worry that I may of deleted it be mistake/accident.
OR
If it doesn't have one is there a third party application of even a Nokia one for Symbian to allow use of FM Radio with the Nokia headphones?
Cheers
G
No, there is no FM radio on the 6680. As the phone does not have an FM radio signal receiver, there is no way a software application would be enough.
There are headsets with an FM radio receiver.
N/A wrote:No, there is no FM radio on the 6680. As the phone does not have an FM radio signal receiver, there is no way a software application would be enough.
yes,but the headsets are not compatible with 6680
Is it possible to install an application that could be capable of enabling the FM Radio feature on fones that lack this one?
Is anybody aware of such an application?
Doesn't seem probable, though, even most other things that are possible on your fone don't seem probable on first thought 😎
YES!!radio headset of nokia IS,i repeat IS compatible with N6680. . njoy :tongue: 😉
if you want a radio just buy one, for god's sake its a phone.
Masada,
I have found the Nokia Radio Headset HS-2R at http://www.nokia.ie/nokia/0,,62248,00.html
It doesnt list this as being compatible with the 6680. Also the enhancements listed for 6680 on any nokia website don't list a radio headset.
have you actually used a headset with your 6680. If so, which one is it?
Spin
HI; my problem now, is how to unlocked or open my nokia 6680,which is locked by 3G network, my sister bought dis unit in england. how could i open this to have an access in networks here in the philippines?
tnx ND GOD speed!
royax
