mine is: N90
V 2.0530.3.5
29-07-05
RM-42
Improvements (as per my observation from the old firmware, .0527)
Font size bigger when composing messages;
White line gone when assigning default numbers and composing message;
Keypad lock now working normal.
Phone response time is faster.
Please feel to post..
**N90/N70 can now work with iSync 2.1.**
Howto: http://www.allaboutsymbian.com/forum//forum/thread/41462/
N90
V 2.0527.2.3
06-07-05
Rm-42
Mine is
N90
V2.0527.2.3
06-07-05
RM-42
N70:
V 2.0534.0.1
26-08-05
Rm-84
mine is: N90
V 2.0530.3.5
29-07-05
RM-42
N70
V 2.0536.0.2
12-09-05
RM-84
I have som problems with the radio on it, read this:
http://www.allaboutsymbian.com/forum//forum/thread/41611/
Here's my new N90 firmware version:
V 3.0545.5.1
07-11-05
RM-42
N70
V 2.0537.1.7
18-09-05
RM-84
Soon to be updated once a have a spare min to get to NSC.
N70
V3.0546.2.3
18-11-05
Rm-84
N70
V 2.0537.1.7
18-09-05
RM-84
I'll let a few more revisions get released before upgrading, hopefully at around 3.7 or 4.0
S.
Yea mine is same as above. Dont you find it really slow and "boggy"????
Sub-Zero wrote:Yea mine is same as above. Dont you find it really slow and "boggy"????
Me? Well I find it mildly buggy (the randomly reverting to the Nokia theme ringtone) but not that slow and I've compared my Orange N70 to a friend's Vodafone N70. However, having said that, it doesn't run as smoothly / fast as my old 7650 did. 😞
If you want to keep the slowness to a minimum then keep all active ringtones and themes in the phone memory and not on the MMC card. You can keep your unused tones and themes on the card and move them back and forth from phone memory as and when you want to use them. Also if you want to minimise the frequency of the phone using the Nokia ringtone then change your log history from 30days to 1 day... Menu > Log > Options > Settings > Log duration.
S.
Mine...
N70
V3.0546.2.3
18-11-05
Rm-84
V-3.0546.2.3
18-11-05
RM-84
As per Steve and N/A told me I keep my N70 running fast reducing the call log up to 1 day and the ringtone and theme I am using in the phone memory
N70
V 2.0539.1.2
19-10-05
RM-84
It is not so slow as some people may tell, and indeed when you keep the theme u use at the moment on your phone memory and when your phone memory isn't too full it is really smooth. I have aswell a 1GB memory card and it reads and writes fast
V4.0603.2.0.3
18-01-06
RM-84
I had the opportunity to upgrade it 2 weeks ago and the improvements seen in all the bluetooth capabilities have impresed me. It works now better with my Blutooth car hands-free as well as with TomTom 5
Talonso wrote:V4.0603.2.0.3
18-01-06
RM-84I had the opportunity to upgrade it 2 weeks ago and the improvements seen in all the bluetooth capabilities have impresed me. It works now better with my Blutooth car hands-free as well as with TomTom 5
Are you sure it is v4? If so this a new firmware recently released.
Woops, just read your post and the date you listed, of course its new! doh
Where did you get it done?
rideon wrote:Are you sure it is v4? If so this a new firmware recently released. Woops, just read your post and the date you listed, of course its new! doh
YES, I do. I'm pretty sure it is release 4. It is not commercial at all. I had the opportunity to upgrade it in Nokia's premises 3 weeks ago. It was the latest beta release they were managing at that time.
Not only enhaces the reliability of my N70 but also adds small useful details such as software key for videocalls (while you dial something the right soft key acts as videocall direct key instead of selecting Options/Make videocall as in v3 and v2), or offers you the possibility to block your camera in each terminating videocall. Small improvements which do N70 even better (at least for me)
Talonso wrote:YES, I do. I'm pretty sure it is release 4. It is not commercial at all. I had the opportunity to upgrade it in Nokia's premises 3 weeks ago. It was the latest beta release they were managing at that time.Not only enhaces the reliability of my N70 but also adds small useful details such as software key for videocalls (while you dial something the right soft key acts as videocall direct key instead of selecting Options/Make videocall as in v3 and v2), or offers you the possibility to block your camera in each terminating videocall. Small improvements which do N70 even better (at least for me)
Sweet, any idea when it will go to final release?
You wouldn't happen to have be able to test tomtom for general reliability with a speed camera database would you?
rideon wrote:Sweet, any idea when it will go to final release?
Yes I have tested TT5.20 with the spped camera databases and the behaviour is now much better than with v3 (not ideal yet but better definately), which proves that Nokia has something to do in all these problems we see.
The point now is that I do not see any hangs in my N70 but TT gets slow from time to time when I am near a PoI. The situation is a little bit different that the crash I used to experience when having v3. Anyway I still have to check the workaround I saw in the post which shows the problems with TT: use the common databse and not the single files. I'm a little bit lazy now to merge all the databses but I'll test it soon. I'll give you feedback as well.
About the relase date, I do not have visibility on that but I guess that new beta versions are to come until making someone as official.
N70
v3.0546.2.3
18-11-05
RM-84
Flashed this morning... not tried it with TT5 yet... hope to soon tho
The process of flashing N70 is done with the same USB cable the comes with the phone or a special cable it�s requiered? does NOKIA has special tools for doing this software update in the phone?
N70
V3.0546.2.3
18-11-05
Rm-84
how to update mo firmware version?? please help..thanks...
how to upgrade my firmware version?????
N90
V3.0545.5.1
07-11-05
RM-42
image taken with N70
N70
V3.0546.2.3
18-11-05
RM-84
image taken with N90
N70.
V 5.0609.2.0.1
01-03-06
Rm-84
