Excel file editor for the Sendo x ?
4 replies · 2,459 views · Started 11 September 2005
Is there a working Excel file editor for the Sendo x ?
I need one to edit time sheets whilst im travelling to various sites so I dont have to carry piles of paper time sheets everywhere :\
Ive tried quick office but it just crashes when installing, ive got the latest firmware for my X.
R
Indeed, QO doesn't work on the X while a lot of users did expect it to work. Afaik there is no excel/office editor for the X available.
trimakassi wrote:Indeed, QO doesn't work on the X while a lot of users did expect it to work. Afaik there is no excel/office editor for the X available.
this is not correct. quick office works very well on the X. contact mobility (quickoffice.com) and ask for an archived version of 2.0 (not premier) as the newer versions will not work.
RIOT wrote:Is there a working Excel file editor for the Sendo x ?
R
Yes there is a program that let you create and edit spreadsheets in your sendo, and even i almost every java powered phone, the software is MicroCalc you can download it from http://mixaz.eatj.com/mc2/index.html get the generic version, is the one I tested.
To intall it, you must copy the two downloaded files in your phone, and then using a File Explorer click on the smallest file and you install the app, and is ready to be used.
Hope it works for you, since is a free version is very simple.
Sorry guys, my bad, this comes as a surprise to me... :embarasse I didn't know about the advanced version, so this sounds interesting to me too.
